Battery isnt charging.
Catylistic
Re: Battery isnt charging.
Post by Catylistic »
Admin wrote:In many case is uncertain what causes the diode to blow. The cathode side need to spare the voltage that trigger the charge light. Thats is not happed in youre case causing the circuit to stay on and drain the battery
So i drove it quite a bit with the new alternator without replacing the voltage reg. Would using a bad voltage regulator cause it to go bad?
probably :D
Catylistic
BOBLOOK wrote:probably :D
I replaced the voltage reg and it charges fine but now when I turn the car off the CHG light stays on. If I leave the battery plugged in too long it will be dead. apparently when the light is on in this instance something is drawing on the battery when it shouldnt be. Any ideas?
