Battery isnt charging.
Catylistic
Post by Catylistic »
About a month ago the CHG light on my '79 corolla wagon started going on but fading away at high rpms. It was only about a week of owning it that this happened and I didnt think to look up what it meant. Not too long after that the light wouldn't fade at all. At this point I decided to take the alternator out and get it tested. It was bad. Bought a new one right there hooked it up and it still isnt charging. Any ideas or help? Also a picture if anyone is curious.
Re: Battery isnt charging.
Voltage regulator bad ?
Catylistic
BOBLOOK wrote:Voltage regulator bad ?
Where would I find that?
Here !
Catylistic
BOBLOOK wrote:Here !
I replaced the reg and it charges now (woohoo!) But now when i turn the car all the way off the chg light stays on and drains the battery if i leave it off for more than 24 hours
Sound that you-re alternator maybe bad?
When you disconnect the battery cable then reconnect it back do you hear an click sound??
If yes on diode is blow in the alternator
Catylistic
BOBLOOK wrote:Sound that you-re alternator maybe bad?
It does click. But it also will stay on if i disconnect the battery telling me its doing its job. Is it still possible for it to charge the battery with a bad diode?
Yes it will charge just fine just the trio circuit diode is blow
Catylistic
BOBLOOK wrote:Yes it will charge just fine just the trio circuit diode is blow
So i guess now i just have figure whats causing it to blow. If i just replace the alt its just going to blow again right?
Admin
Site Admin
Post by Admin »
In many case is uncertain what causes the diode to blow. The cathode side need to spare the voltage that trigger the charge light. Thats is not happed in youre case causing the circuit to stay on and drain the battery
