Look what I found!
Posted: Sun Jan 05, 2014 11:50 pm
by baldo
I was thinking about making one and they sell them already.
Re: Look what I found!
Posted: Mon Jan 06, 2014 1:40 am
by 73GTV
For less than $180.00 each, could work, that would be a cool look.
Posted: Mon Jan 06, 2014 4:37 pm
by baldo
Yes thats why I want to get it.
Plus I figure it would help with having two cylinders richer than the other two with the original single dcoe intake.
Posted: Mon Jan 06, 2014 8:56 pm
I would use two with an 2TB intake not sure if it clear those both weber but will look nasty
Posted: Sun Jan 12, 2014 6:05 pm
by 73GTV
BOBLOOK wrote:I would use two with an 2TB intake not sure if it clear those both weber but will look nasty
You and I are thinking the same way, That would be very cool indeed.
Posted: Mon Jan 13, 2014 4:50 pm
Yes hope to see an picture one day someone doing it
73GTV wrote:BOBLOOK wrote:I would use two with an 2TB intake not sure if it clear those both weber but will look nasty
Posted: Mon Sep 15, 2014 8:52 pm
by baldo
Coming soon to a car near you!
Not with a 2tb intake, I thought about it before you guys because I found it first.
But those intakes are hard to find and are rare......... Get it? By the time I get the part and maybe a few jets it will be done hopefully by the end of the month.
Posted: Mon Sep 22, 2014 10:33 pm
by baldo
Few updates with 2 problems.
It fits and its an interesting look but, If it faces the struts its so close I wont be able to put a filter or stacks. Not good! If it faces the engine I will need a spacer (that I can get) but then its too high and will hit the hood. So I need a hood scoop $100 or hammer the strut tower 2mm........ FREE
I can also get an adapter to face the front but it will be about $250, not worth it.
Posted: Sat Oct 04, 2014 11:26 pm
by cousin eddy
Id like to use that with a single SU
Posted: Thu Nov 20, 2014 7:11 am
by AE25
pity the bolt pattern isn't square and the hole round or square.. an adapter wouldve been the better option. Currently the flow path would be a bit interrupted?
You know a basic 15mm thick alloy adapter plate can be done online. ie draw it in CAD (Or pm me some exact measurements as it doesn't take long) and save as a .dxf file and take it to a water cutter.. or order it online, companies do this! Then drill/tap threads in for the studs. may have to counter/bore cap screws in there to hold the adapter down if the carb overlaps.
