Look what I found!
Look what I found!
I was thinking about making one and they sell them already.
- Attachments
- KC190-250.jpg (38.89 KiB) Viewed 18136 times
Re: Look what I found!
For less than $180.00 each, could work, that would be a cool look.
Yes thats why I want to get it.
Plus I figure it would help with having two cylinders richer than the other two with the original single dcoe intake.
I would use two with an 2TB intake not sure if it clear those both weber but will look nasty
You and I are thinking the same way, That would be very cool indeed.BOBLOOK wrote:I would use two with an 2TB intake not sure if it clear those both weber but will look nasty
Yes hope to see an picture one day someone doing it
73GTV wrote:You and I are thinking the same way, That would be very cool indeed.BOBLOOK wrote:I would use two with an 2TB intake not sure if it clear those both weber but will look nasty
Coming soon to a car near you!
Not with a 2tb intake, I thought about it before you guys because I found it first.
But those intakes are hard to find and are rare......... Get it? By the time I get the part and maybe a few jets it will be done hopefully by the end of the month.
Few updates with 2 problems.
It fits and its an interesting look but, If it faces the struts its so close I wont be able to put a filter or stacks. Not good! If it faces the engine I will need a spacer (that I can get) but then its too high and will hit the hood. So I need a hood scoop $100 or hammer the strut tower 2mm........ FREE
I can also get an adapter to face the front but it will be about $250, not worth it.
cousin eddy
Id like to use that with a single SU
pity the bolt pattern isn't square and the hole round or square.. an adapter wouldve been the better option. Currently the flow path would be a bit interrupted?
You know a basic 15mm thick alloy adapter plate can be done online. ie draw it in CAD (Or pm me some exact measurements as it doesn't take long) and save as a .dxf file and take it to a water cutter.. or order it online, companies do this! Then drill/tap threads in for the studs. may have to counter/bore cap screws in there to hold the adapter down if the carb overlaps.
