On the old site I remember seeing a few rack and pinion write ups. One I believe someone did it on an old 70s corolla using a starlet rack and pinion. If the author of those write ups would happen to have the info/ pictures still I would highly appreciate it. I tired of turning my wheel half a turn before the car turns
rack and pinion swap.
Hello fellas,
thanks in advance.
Re: rack and pinion swap.
http://s306.photobucket.com/user/vercju ... =3&page=14
His phobucket is set for public so you can brows true them
connor72 wrote:Hello fellas,
On the old site I remember seeing a few rack and pinion write ups. One I believe someone did it on an old 70s corolla using a starlet rack and pinion. If the author of those write ups would happen to have the info/ pictures still I would highly appreciate it. I tired of turning my wheel half a turn before the car turnsthanks in advance.
Thank you! This is exactly what I was looking for. Time to gather parts for the summer build.
I feel like its harder to find parts then it is to actually build when it comes to these cars
I also found a few pictures of someone using a aw11 rack. I have no idea the difference in size between starlet and mr2 racks but I know mr2's are much easier to find. Again. Thanks for the info.
Your welcome for wat car are you plan to do this conversion ??
connor72 wrote:Thank you! This is exactly what I was looking for. Time to gather parts for the summer build.I feel like its harder to find parts then it is to actually build when it comes to these cars
It's a 1972 te27. I'm also thinking about going 20v for ease of use and because I want a DD. So I might pm you in the coming months to ask about your peanut in the future. thanks again
if your going to do the swap on a te27 I suggest you just find a starlet rack its better to work with the aw is longer, I did this swap on my car if you can get the steering column from a starlet that would help to
I figured the starlet would work better. Too bad. I've seen quite a few mr2s in the junk yard. Can't say the same about the starlet though. I could just buy a new rack and pinion and stuff. Talk about $$$
I don't own an peanut
connor72 wrote:It's a 1972 te27. I'm also thinking about going 20v for ease of use and because I want a DD. So I might pm you in the coming months to ask about your peanut in the future. thanks again
Well shoot. I feel stupid now.
I read your first post wrong.
