Mr track car!
Warren
Mr track car!
Post by Warren »
So I havn't really had a build thread on here, for obvious reasons(Not 3tc yet), but anyways. I will start with some photos and maybe back track to how it got here.
So the basic are:
chassis
1980 Canadian TE72, a little beat up but not too rusty.
86 front suspension, koni race, 8kg springs, 40mm RCA, BCWorks LCAs/Knuckles/Tierods. Battel Version style rack spacers.
6kg swift springs with HTS short stroke rears.
GTS 6.7" with a spool full heim 5 link with relocated uppers, under the seats so it still has full interior!
Drivetrain
AE101GZE bottom end, OEM .040 oversize pistons, ARP most things, cometic 1mm HG, BCWorks tubular exh mani/downpipe/Intake, 1ZZ coils, GT2560R at 10psi, SARD FPR, walbro 255LPH pump, denso 440cc injectors (7mgte), MS2. ~200whp
W58 trans with an ACT 6 puck.
The engine/trans have been moved back 40mm also.
Here are my 3 cars!
I will find some high lights later!
BCWorks
Re: Mr track car!
Wow the onboard upload attachment work like a champ no more photobucket drama ! ;)
Warren
Re: Mr track car!
Post by Warren »
Does it just auto upload any linked image?
BCWorks
admayen
Re: Mr track car!
Post by admayen »
Awesome Warren! Is the front bumper on the white TE stock? If not, where did you get? :D
hemilove
Re: Mr track car!
Post by hemilove »
very nice sir do you happen to have any pics of your rear end set up what did you do to make it so low im wondering
Warren
Re: Mr track car!
Post by Warren »
The bumpers are off a north america spec TE51.
The rear was a lot of work. I clearanced all of the stock bump stock location, moved the upper link pickup points on the chassis higher, and dropped the lower link mounts on the axle side. I will post some pictures tomorrow.
BCWorks
Warren
Re: Mr track car!
Post by Warren »
BCWorks
Warren
Re: Mr track car!
Post by Warren »
BCWorks
Warren
Re: Mr track car!
Post by Warren »
BCWorks
Warren
Re: Mr track car!
Post by Warren »
flipping a smallport(FWD) intake, also adding a larger 65mm throttle body. I think from a van, but I don't remember.
BCWorks
