w series trans.
w series trans.
I am sure there was much more info on the old site. just thought this would be a good start for us to regroup.
Does anyone have any experience with the fitment of the w series trans in the early "toy" rolla's? Such as my te27. I have some "big" stuff planned and after some research it sounds like this would be the tranny for me.
Re: w series trans.
W55 & W58 from a celica you can do the bell if you can get some 1 to weld it for you,,not so hard to do
Re: w series trans.
if you need help let me know. ive done a bunch of these in the past and its easy.
Mazota TE51
Re: w series trans.
Is there a w58 tranny better than another to install in a TE72. Trying to avoid having to install a R154 tail. I can get my hands on a w58 off an 81 supra.
Mazota TE51
Re: w series trans.
Anybody? Didn't some celicas com with an iron gearbox or something? Maybe not iron but there was something special about it.
Re: w series trans.
La w55 is aluminum y la w58 tiene the middle plate en steel y the gear ratio is a bit different and I think they both share the same shifter plate so to slide it back u gonna have to get the plate out of the 154''' but that's a piece of cake to do just remember you need the 3 parts'''
Mazota TE51
Re: w series trans.
For some reason I thought that the early celicas (74-77 or so) fit by just swapping the bellhousings and were strong as hell. I am going to find out with a guy I know to verify. I have R154 tranny's but I would just hate to take the tail housings off them if I don't need to. Its for a street car maybe una pela here and there.
Re: w series trans.
Not true, there are different versions of the W58 as well as the W55-59 yes gear ratios are a little different from the truck ones and the car ones!toyotero2dend wrote:La w55 is aluminum y la w58 tiene the middle plate en steel y the gear ratio is a bit different and I think they both share the same shifter plate so to slide it back u gonna have to get the plate out of the 154''' but that's a piece of cake to do just remember you need the 3 parts'''
- skellington
Re: w series trans.
I need help with this. A W58 fell in my lap today. I plan to replace my A40 slushbox with it. I have started to put in the 3rd pedal. Crossmember will be easy. What do I do for a bellhousing? adapter? clutch system?
1974 TE27 TWINS!
#2 viewtopic.php?f=27&t=2036
Re: w series trans.
Island chain racing a member here he does made those adapters bro, pm him he is an awesome guy !skellington wrote:I need help with this. A W58 fell in my lap today. I plan to replace my A40 slushbox with it. I have started to put in the 3rd pedal. Crossmember will be easy. What do I do for a bellhousing? adapter? clutch system?
