Question Billet Block
73GTV
Post by 73GTV »
Has anyone had a source for a CNC Billet block for the 2TC and 3TC engine? If so, can you share that information, please?
Re: Question Billet Block
Haven't see any so far.
AE25
Moderator
Post by AE25 »
Have you reached the limit of the stock block? Or cant find any decent ones.
Curious what power you're getting out of them
Back then when the big boys experience limit they swap for 4Y blocks.
73GTV
Post by 73GTV »
So the answer is no!
Then no one has improved or corrected the design errors as of yet.
73GTV
Post by 73GTV »
BOBLOOK wrote: Tue Jan 18, 2022 10:36 am Back then when the big boys experienced limit they swap for 4Y blocks.
So go from a front mount oil pan to a rear mount oil pan.
Which cross member will they have to use for that engine installation?
Which timing chain cover would be used to seal this system?
Count the head bolts!
Look at the front of this block and let us see how any of the standard timing covers for a 2TC, 2TG and 3TC can be secured to this block!
73GTV
Post by 73GTV »
AE25 wrote: Mon Jan 17, 2022 11:24 pm Have you reached the limit of the stock block? (Or can't find any decent ones.)
Curious what power you're getting out of them!
That was not the direction for this leading subject. Does anyone have a source for a Cad-designed block as a replacement for the 2TC and 3TC engine block!
Standard design or redesigned was where I was going with this subject. (Focus!)
The redesign question was to ask about oil squirters for cooling below the piston crowns, or the addition of a four-bolt main for the crankshaft.
Correction of the oil supply issues to the third and fourth cylinders.
There would be additional modifications to increase the overall output from this engine design as well as needed improvements to increase the cylinder wall thickness to allow for an increase in overall bore limits.
That was why I asked this question in the first place.
73GTV wrote: Tue Jan 18, 2022 5:37 pm
It was an race car i can't see any drysump oil system
Race car no cross member
Am pretty sure custom 4y
5 visible 5 inside the valve cover
Check some pictures
If my memory can recall i do remember the racingstore was selling a kit for the 3tc 4y conversion but was an way back old forum time.
