U-Joint yoke to differential flange
totorote27
i am looking for the flange that is on the rear of the drive shaft that mates up to the differential pinion flange for a 1974 toyota corolla. i am trying to install 74 axle into a 72 corolla and went to bolt it together and then discovered this issue. the bolt pattern on my 72 driveshaft is a little smaller and not symmetrical like the 74 differential. my hope is to get the correct flange for the driveshaft and press off the old one then press on the correct flange. need this or another solution ASAP. thanks
Re: U-Joint yoke to differential flange
Not interchangeable. Just run 2 bolts kitty corner. Can also drill other 2 holes, Done it many times, only takes 10 mins to drill 2 holes.
totorote27
Yep. Came to that realization and drilling is what I I will do. Thanks for the reply
