Aloha from Norway.......
Nice to se the forum is back again.
I have own my Corolla for 13 years now,using most of the time building it to the way i want it.
Thanks to all the kind people who has contibuted to make this happen......
Enjoy........
Exterior:
1982 Corolla TE71L GT Doch.
Nice and clean body with all new bodypanels. (NOT easy to get good bodypanels anymore.)
Painted in 8K8 Dark blue.
Foha frontlip
Genuine (rare) back visor.
Volvo 360 spirit back spoiler.
Dohc stikkers on the sides in reversed colours.
16" Rota RB silver with Vredestein 195-45-16
Interior:
Recaro seats in front
Stock backseat , upholsted with recaro fabriq to match front seats.
Momo steering wheel
TRD leather shift knob
Boostcontroller and gauges in a custom center console.
Engine:
3T-GTE with 87 mm bore.
Moroso alu pan
Modified 2T-G oilpump
Calito CT1 coated bearings
Crankshaft balanced and polished.
Crankshaft pinned to flywheel
Pauter X-beam conrods.
Arias 8,5:1 pistons
Cometic headgasket
All bolts and studs are ARP
Resurfaced block and head.
Ported head.
WW bug pack valve springs
2T-G , 222 camshafts
Kameari adjustable camwheels
New timingchains and tensioners.
Earls oilcooler.
AN fittings and steinless steel braided hoses.
Air/fuel management:
Stock fueltank with custom surge tank.
External Bosh 0044 fuelpump
550cc RC engineering injectors
Aeromotive fuelpressure regulator
Mallory canister fuel filter.
Modified fuelrail with feed in both ends.
Custom made stainless steel exhaust manifold.
Borg Warner EFR 6258 turbo
Custom made stainless steel 3" downpipe.
Front mounted alu intercooler
Custom made upper intake manifold.
Stock lower intake manifold.
Electromotive tec2 with direct ignition , windows chip. Fully adjustable.
Drivetrain:
W55 trany.
Centerforce dual friction clutch kit
Volvo 1031 rear end with truetrack diff.
Modified driveshaft
Suspension and brakes
Cusco camber adjusters
T3 coilovers in the front,with Koni shocks
25 mm front sway bar.
20 mm rear sway bar.
T3 coilovers in the rear,with tokico short stroke shocks
T3 Adjustable control arm
Wilwood brakes in the front. 300mm rotors and 4 piston calipers.
Toyota hiace main brake cylinder.
Stock volvo brakes on the rear end.
Girling hydraulic handbrake
++++++ Lots of part i have forgotten.....
