																			 TE27007
						Post
								by TE27007 »
			So I took pictures of the carburetors side by side for anyone that would like to use this for reference.
First up is the Manual choke Carburetor off my 1971 Corolla.
Here are the carbs side by side
The electronic carb
						Post
								by BOBLOOK »
			Work the same the only thing is added is electronic element for the choke and shutvalve solenoid .
Both are 12v switched power source
																			 Rodger
						Post
								by Rodger »
			As Bob said.  Both operate mechanically the same.  You may have different jets which could benifit when tuning.
The question to ask is:  If you choose the carb with electrical devices, do you have any idea where to connect them?
I'd choose mechanical as that gives less things to think about and connect up.
Regards
						Post
								by BOBLOOK »
Regards
Any 12V switch source..........  Don't use the 12v coil +
																			 TE27007
						Post
								by TE27007 »
			Thanks gentlemen. I opted for a Weber Carb in the end. Both Carb are up for sale.
