Biggest wheels I can use
So what are the biggest wheels I can use before I have to roll the fenders or hammer the shocks to make a wheel fit? If you cant tell by now Im not about to do that!
I have seen 17s and they look nice but not for my car. I want to keep the "racing look". Just drop it a bit and no mods or hammering. Im thinking 15s are as big as I can go, but I can find 16s and dont know if it will fit without problems. I know the width has to do with it, Im just concerned about the hight with stock everything.
Re: Biggest wheels I can use
Thats what I thought. I am going for the racing look so those rims are a no go. But thanks man!
Weld racing 15x 3.5" rim 135r tire,front,,,,15x7 4.5 rear spacing 225/50 tires For the rear you might like this combo. Baldo
- oldeskewltoy
A 16" wheel with the correct offset should work fine. The real concern is what tire you want to run.
Toyotero knew where I was going!
But after thinking about it I would need more HP to move the bigger tires and keep everything how its supposed to. I think Im going to go 14. The reason was because the rims I wanted worked perfect with the rims I got, so I needed 15s in the back. And its too hard to find big size 13 tires now.
I might try going 15 when my engine is done. I dont think 16 will work cause I want big tires.
So what is the most positive offset that can fit in the back? +35 looks to be a bit much. I can find some +20. I rather have 0 but if something else fits...... Pics with 14 and 15 inch rims on a toyota welcome!
