Is their a easy way of changing the oil pan gasket, or the whole oil pan out with out having to drop the engine ?
In a TE21 2tc or corolla thanks.
Oil Pan Gasket
bryanhernandez3727
Oil Pan Gasket
Corolla Kid
トヨタ
トヨタ
Re: Oil Pan Gasket
Possible but difficult. I have done it in a TE27 which will be the same. I needed to drop the oil pump to remove the pan. I actually changed the crank while in the car but would have been faster and easier to pull the engine. But just the oil pan, I wouldnt pull the engine.
Re: Oil Pan Gasket
It can remove the engine mount an jack it as high as possible so it can clear the pan. it shall work
- mallito1.8
Re: Oil Pan Gasket
That's correct I loosen my engine mounts to remove my oil pan to tap in a return from the turbo and a little tight but it'll come out.BOBLOOK wrote:It can remove the engine mount an jack it as high as possible so it can clear the pan. it shall work
Re: Oil Pan Gasket
Done it many times this way on jack standsmallito1.8 wrote:That's correct I loosen my engine mounts to remove my oil pan to tap in a return from the turbo and a little tight but it'll come out.BOBLOOK wrote:It can remove the engine mount an jack it as high as possible so it can clear the pan. it shall work
