Sloppy differential
Sloppy differential
Hey guys I just recently had my Weir performance lsd rebuild installed in my oem ae86 lsd and there is still play in the differential just like before the rebuild was installed. I also have a 2.93 Richmond gear set installed. Any ideas?
Re: Sloppy differential
play? please explain. there has to be just a tad inorder for the parts to work correctly.1.8te27 wrote:Hey guys I just recently had my Weir performance lsd rebuild installed in my oem ae86 lsd and there is still play in the differential just like before the rebuild was installed. I also have a 2.93 Richmond gear set installed. Any ideas?
mikealike wrote:play? please explain. there has to be just a tad inorder for the parts to work correctly.1.8te27 wrote:Hey guys I just recently had my Weir performance lsd rebuild installed in my oem ae86 lsd and there is still play in the differential just like before the rebuild was installed. I also have a 2.93 Richmond gear set installed. Any ideas?
The guy who installed the rebuild didn't measure anything or set the backlash correctly, very halfass and very frustrating. Now the lsd unit is at Weir and a local guy is setting the clearances.
