Head leaking bad!
Head leaking bad!
My 3tc head is leaking bad! Its a double springed head with bigger valves port and polished and shaved dont know exactly how much was shaved i but i know its shaved..... Now it keeps leaking bad but not from the gasket from inside the rear 3 and 4 exaust ports, i just put all new valve steam seals and still the same leak am gonna take it to the machine shop tomarrow to see if its cracked but first wanted some feed bavk from you guys to see what you guys think
Re: Head leaking bad!
Be more specific, what it is leaking? OIL, WATER, intake charge
Like bent valves?
Its leaking oil and valves are not bent there in good condition
Did you use felpro seals? Those things are rubbish, I always get problems with them.
am just wondering how is it thats its the same two valves that am having problems with....when i take the header off the 3 and 4 exhaust ports are soaked in oil
How are the spark plugs? Could be the valve cover seals. I am guessing the car is smoking and running really rough........
Those are also new.... New head gasket, new valve seals and valve cover gasket and spark plug tube seals and still the same dam leak
So is leaking inside the combustion chamber?
I got a experience before with a wrongly ported head that the valve spring pressure broke into the intake port with a tiny crack, u can check on that as well as in the exhaust side, some think anyone can port a head but sometimes almost 80% of those are dead wrong LOL
piston rings?
