Page 2 of 2
Re: Question Billet Block
Posted: Tue Jan 18, 2022 10:18 pm
by 73GTV
BOBLOOK wrote: Tue Jan 18, 2022 6:55 pm If my memory can recall I do remember the racing store was selling a kit for the 3tc 4y conversion but was a way back old forum time.
So to use that block you had to get a different or make a specific head for that block.
That is not a standard T-series head based on the water outlet missing from that photo, but as you stated a racing engine.
Have you any information about using a 2TG head on that block which should bolt-on without an issue.
Thank you for that fast response.
Posted: Wed Jan 19, 2022 5:14 pm
73GTV wrote: Tue Jan 18, 2022 10:18 pm
Before the billet era was just the stock head modified to the block I was not there to know the exact details.
This one look taller than the others in the market. But the water outlet is optional, usually they don't run water true the block since the block is filled. Just an little water true the head. The fitting in the front is water some use the ice water from the water to air intercooler system
Not have !. The timing Chains design was kinda drama. You couldn't shave much of it
Posted: Wed Jan 19, 2022 5:15 pm
Posted: Wed Jan 19, 2022 8:37 pm
There is an guy who is building an DOHC 3TC 16V head Emiliano Rosario he is on 3tcgarage fb page.
Posted: Thu Jan 20, 2022 9:20 pm
by 73GTV
BOBLOOK wrote: Wed Jan 19, 2022 8:37 pm There is an guy who is building an DOHC 3TC 16V head Emiliano Rosario he is on 3tcgarage fb page.
Thank you for your input.
interesting that all of the information that I just read stated that the 4Y engine would not hold up to high RPMs. So no use sinking time chasing that bit of effort.
Posted: Fri Jan 21, 2022 7:08 am
73GTV wrote: Thu Jan 20, 2022 9:20 pm
The block might hold i read the crankshaft weak spot.
