ignition coil pack wiring info needed for rpm tac
781masshole3tc
Post by 781masshole3tc »
hello again, im hooking up my tac and i need to know which wire is (+ and -) so i dont fry my tac, 80 3tc 5sp with square style coil, is the (-neg) towards the front or back of the car. the coil is properly mounted in the stock location (fyi) thanks
Estebot
Re: ignition coil pack wiring info needed for rpm tac
Post by Estebot »
Safest would be to go to the manufacturer of you tachs website and look at the instruction sheet there. Will tell you what wire to clip and what wires go to pos and neg.
The igniter itself has its tach output signal connector
781masshole3tc
Estebot wrote:Safest would be to go to the manufacturer of you tachs website and look at the instruction sheet there. Will tell you what wire to clip and what wires go to pos and neg.
thanks for looking out very much appreciated but i already have that info, my question is all together different.
781masshole3tc
thanks bob ill go outside in the day time and look for it.
Post by mikealike »
781masshole3tc wrote:thanks bob ill go outside in the day time and look for it.
negative side of the coil works all the time
Not when u use the igniter it can interrupter the work of the ignition
Not when you use msd box therefore you need to use the tach output
781masshole3tc
is this the tach wire im holding Bobby?
is it yellow ?
61Alpine
Post by 61Alpine »
There are 2 types of tacs - Voltage & Current.
I spent weeks trying to figure out how to wire a '62 Alpine (current) tac to a 3tc engine & igniter. The Alpine info says key sw. B+ thru a loop outside the tac to the coil +.
Surely that wouldn't work according to all the Toyota info. But it does work perfectly!
