Distributor upgrade question
skellington
Post by skellington » Sun Dec 08, 2013 7:21 am
My 76 is set up with a point’s style distributor. If I have an electronic distributor that will bolt in, will I have to change anything else out?
-Have 1976 TE31, new distributor is from 3tc 1983.
Re: Distributor upgrade question
Post by BOBLOOK » Sun Dec 08, 2013 10:17 am
You can use the electronic, you need also the ignition module( igniter) and coil for the wiring not a big deal the diagram show how to connect the igniter
This one is DIY work fine
Grumpy3TC
Post by Grumpy3TC » Wed Apr 02, 2014 1:36 am
BOBLOOK wrote:You can use the electronic, you need also the ignition module( igniter) and coil for the wiring not a big deal the diagram show how to connect the igniter
Where can I find this electronic upgrade? BOB?
MY 3tc is so Grumpy! I feel like eating one or two Rotaries for breakfast today!
Post by BOBLOOK » Wed Apr 02, 2014 11:31 am
Forget about this and buy an MSD 6 serie ;)
Grumpy3TC
Post by Grumpy3TC » Wed Apr 02, 2014 10:08 pm
BOBLOOK wrote:Forget about this and buy an MSD 6 serie ;)
I already have a 6A,I have to re-read the subject and relearn the principal again is been a long time since a dont read.Thanks
Post by BOBLOOK » Thu Apr 03, 2014 9:16 pm
Foxau2
Post by Foxau2 » Sat Apr 05, 2014 12:49 am
It's a lot easier if you get the electronic dizzy and ignitor out of the same car so you know they match up. That's what I did and it was a 20 minute process to install.
3TCgo
Post by 3TCgo » Thu Jul 03, 2014 3:06 pm
Hi guys. bump for an old thread. has anyone used an after market distributor? Anything from mallory, accel or any other that is basically drop in. If so share info please...
73te27
Post by 73te27 » Fri Jul 18, 2014 3:44 am
A lot of those are dual point which is just double the headache. Stock electronic with upgraded ignition is fine for most people. Set it once and done.
If you do happen to find the electronic ones then you better also stock up on cap and rotors.
