Any ideas? Parts wanted.
Luisito
Post by Luisito »
I wanted to know everyones opinion, i have a stock 3tc 1.8. Later down the road wanted to add a few things 8-)
Want to know best part brands and best fits.
Idk too much about aftermarket parts, other than stock lol.
Header ( which fits and performs best )
Full exhaust ( dont want it loud ) cat, muffler etc..
Weber ( tipical, the one everyone has )
I want to keep it 1.8 3tc but i want it 5 speed and for it to perform better.
Who ever has ideas or PHOTOS of there work, let me know what i should go for?
Tatequieto
Will
Pufito
Something like yours
Stock but performance
Oh.. Also my starter keeps messing up i changed it about 3 times in the past 2 years :evil:
Also would like a stronger alternator. More volts basically something that fits on without modifications that let more power.
Re: Any ideas? Parts wanted.
Post by mikealike »
Luisito wrote:I wanted to know everyones opinion, i have a stock 3tc 1.8. Later down the road wanted to add a few things 8-)
Tatequieto
Will
Pufito
Parts for t series are slowly diminishing since the new engines are more popular. I used Doug Thorley headers and a mildly ported head with a 32/36 weber carburetor, small 292 cam. Exhaust i used was a mandrel 2.5 tube exhaust with a silencer and a 50 series flow master. Ignition to use is a MSD 6 series unit.
Luisito
Post by Luisito »
Sounds good, and your right these performance parts are going to be difficult to find a couple years from now. That's why I want to perform my engine so it can run stronger. I want to keep up to a Honda basically lol. Stock I actually did pretty well keeping up. Do you have any pics?
toyotero2dend
Post by toyotero2dend »
hey Luisito my old engine has a 296 cam,,alil porting on the head,,, short intake,, dual 45 side draft ,,a msd 6al ,, header is a pacesetter ,,exhaust 2 1/2" ,, muffler 2 chamber flew master ,,if you can get your hands on a tranny out of the twin cam corolla they a bit stronger ,, and also the differential ,, as per the charging, you can get an alternator out of a 1st gen rx7 they work great all you need to do is grind abit off the corolla bracket ,, get a bronze clutch and a good pressure plate ,, you be good to go ;)
TPR Motorsports
Post by TPR Motorsports »
Ur starter problem is just bad connections to your starter solenoid, that one wire has several connections n over time they get corroded, u can trace the wire on the switch on the steering colomn n run a wire straight from there to the starter solenoid, starter problem fixed!!! I do this to all my corollas, works everything when I start getting the clicking issue with the starters.
Good luck man
Carlos Diaz
TPR Motorsports
Paypal: TPR3TC@yahoo.com
803.334.8674 (text friendly)
Was your starter issue the click illness ??
For the starter you can use the saturn conversion
toyotero2dend
do the relay for the starter Bob has the instructions in his post ;)
