Shifter Shaking
bombapinoy
Shifter Shaking
Post by bombapinoy »
My shifter shakes like crazy when i maintain speed in gear usually 3-5. I'm guessing thats the transmission mount thats the cause however I am open to more suggestions. Any idea guys? Also if it is the mount will the ae86 tranny mount work? Its for a TE72 and same t50 tranny. Thanks guys!
Re: Shifter Shaking
transmission mount
toyotero2dend
Re: Shifter Shaking
Post by toyotero2dend »
you might wanna check the drive shaft bearing,,mount should be the same too
bombapinoy
Re: Shifter Shaking
Could the possibility of the shifter needing a rebuild be the cause? I've heard anything after 100k miles will make you have a bad shifter. If so could I just get a rebuild kit for ae86 since they share the same tranny? Cuz I'm not sure how good the short shifters feel are. I like the intentional throws that you have to do on the stock but at the same time it would be nice to have shorter throws.
