Te72 clutch on ae71 no pressure
80Corollin
Post by 80Corollin » Tue Nov 03, 2015 2:12 pm
Like the title says.
Swapped an ae71 sedan with a 3tc and t50
Car had been swapped previously..then had the auto 4ac dropped back in.
But we cannot seem to build ANY pressure in the pedal..
New master cylinder (clutch)
New hard lines. Bends are fine. And no blockage.
Any help?!!!! :o :oops:
Re: Te72 clutch on ae71 no pressure
Post by BOBLOOK » Tue Nov 03, 2015 7:03 pm
Clutch slave cylinder ?
oldeskewltoy
Post by oldeskewltoy » Wed Nov 04, 2015 4:35 pm
did you bleed it?
80Corollin
Post by 80Corollin » Thu Nov 05, 2015 2:40 am
We've bled it and still feels soft.
Everything is new.
it was previously and auto.
When he pushes the clutch in. It flexes on the firewall.
oldeskewltoy
Post by oldeskewltoy » Thu Nov 05, 2015 3:59 pm
firewall movement is quite common, it shouldn't make the pedal "soft". If the pedal is "soft", it still is likely a bleed issue.
