808TurboCorolla
808TurboCorolla
808TurboCorolla
808TurboCorolla
Re: 808TurboCorolla
I am having a difficult time posting pics of the build
I will try again later.
808TurboCorolla
Re: 808TurboCorolla
Now for the manifold build
- Attachments
- image.jpg (35.94 KiB) Viewed 63203 times
- image.jpg (35.21 KiB) Viewed 63203 times
- Since I didn't have a helper I used a guava stick to hold the turbo for me.
- image.jpg (31.74 KiB) Viewed 63203 times
808TurboCorolla
Re: 808TurboCorolla
Weld weld weld..
- Attachments
- image.jpg (33.82 KiB) Viewed 63203 times
- image.jpg (36.4 KiB) Viewed 63203 times
808TurboCorolla
Re: 808TurboCorolla
I forgot to put this in there, stock 2TB cast pistons.
- Attachments
- image.jpg (192.91 KiB) Viewed 63201 times
808TurboCorolla
Re: 808TurboCorolla
Ready to rock and roll!!
- Attachments
- image.jpg (35.23 KiB) Viewed 63200 times
- image.jpg (34.23 KiB) Viewed 63200 times
808TurboCorolla
Re: 808TurboCorolla
Stock 2T 18psi boost pump gas water meth
11.20's
11.20's
- Attachments
- image.jpg (21.28 KiB) Viewed 63199 times
- image.jpg (22.76 KiB) Viewed 63199 times
Re: 808TurboCorolla
Shawn this is you right?? You not on facebook anymore??808TurboCorolla wrote:Stock 2T 18psi boost pump gas water meth
11.20's
Re: 808TurboCorolla
Is that a fuel solenoid that is on the side of the carburetor? Great project by the way!!!!
32/36 weber blow thru 12psi t3/to4b
