anyone with coilovers...springrate question
Im looking at coilover conversion kit from t3 for my 82 te72. What springrates do you guys have? Its my daily driver, only going to lower it a little bit not slammed or anything, function over form for me. What would be a good rate for the lil te72?
82 te72, 1.8 3tc, cam, headers, weber 32/36. ALOT more to come!
Re: anyone with coilovers...springrate question
front would have to be in the 300 range and the rear is in the 250 range. I use 350 in the front of my rolla and the rear is soft do to launch and track only...I hope this helpsosrolla wrote:Im looking at coilover conversion kit from t3 for my 82 te72. What springrates do you guys have? Its my daily driver, only going to lower it a little bit not slammed or anything, function over form for me. What would be a good rate for the lil te72?
- rolla_rage
I had 250lb/in up front on my fully trimmed wagon daily driver. It may have been a bit stiffer than stock, but still very much a daily; not too stiff. I would maybe go up to about 300, above that its prob start feeling pretty rough. After adding about 100lbs of weight with an engine swap I now run 325's and it is pretty good mix of stiff and decent ride.
-J
-J
ulises_te72
- rolla_rage
Sweet! I'm curious, what did you use for trans and rear axle? Did you have to cut the tunnel up quite a bit? What kind of power are you making?
My wagon weighs 2550lbs and I run 325lb/in up front. I think they are just right for daily driver and hold their own for a little canyon carving. I've been running tokico blues up front, but I've never quite thought it was enough dampening. This next week I plan to modify my strut tubes and install sw20 AGX adjustable rear cartridges up front.
-J
Thats easy, cressida or supra everything in the front!
ulises_te72
rolla_rage wrote:Sweet! I'm curious, what did you use for trans and rear axle? Did you have to cut the tunnel up quite a bit? What kind of power are you making?
-J
No modification to the tunnel, just a little bit of denting to fit the bell housing, i did drop the crossmember 1 in to push the engine a little more back. No cutting what so ever. The power its great, i am using a toms tech computer, water/air intercooler, 440cc injectors, 3in exhaust and 14 pounds of boost. My rear end is stock but i am fabricating a ford 8.8 rear end at the moment.
- rolla_rage
Very cool, clean install too!
