Ae86 brake lines on a te72
superdevil
Just curious if I could get SR5/GTS AE86 braided lines for my wagon. Naturally no one sells lines specifically for the wagon. I have ae86 brakes up front so it should work haha?
Re: Ae86 brake lines on a te72
The front will work !
The back will work only if you have the GTS rearend disc conversion
Stock wagon rearend use 1x hose in the center of the diff
superdevil
Ah ok, so a rubber line leading to 2 hard lines in the rear?
Yessuperdevil wrote:Ah ok, so a rubber line leading to 2 hard lines in the rear?
