Corolla 77 torque bar
montrealte31
Post by montrealte31 »
Hi!
I would like to instal one torque bar to my frame to differential
Their is not very much room, where should i instal it?
montrealte31
Re: Corolla 77 torque bar
i bought those, i just gona have to get the metal bars and choose the size to fit them.
Is it possible to install it from the rear?
montrealte31
I ve look at what this guy did,
Re: JSP f22 turbo AE86
by john russakoff » Fri Nov 29, 2013 9:55 pm
does it need to be make like a Y
or it could be only one bar that goes from the diff to the body ?
Does it need to be two torque bar or only one could work?
thanks
toyotero2dend
Post by toyotero2dend »
Check this out. The one that says Slide a link,,,
A revolutionary, patented, completely bolt-on traction device, the Slide-A-Link™, designed for both street and strip use is track tested and competition proven to outperform conventional “Slapper” bars. A solid mounted front plate is installed inside the original front spring pocket and clamps to the leaf spring to provide a positive displacement for the torque that is transmitted from the rear axle through the telescoping bar and special durometer shock pad. These forces, along with improved instant center geometry, provide better weight transfer for increased traction. Free travel and pre-load adjustments are made on the vehicle by adjusting the jack screw at the rear of the bar. http://www.competitionengineering.com/a ... assis2.asp
coitre20
Post by coitre20 »
I will likely be going with a rear setup similar to this. I don't know if this will work with a stock exhaust system but it is a nice setup.
Here's a link to the build page...
http://www.rollaclub.com/board/topic/51 ... e__st__240
toyotero2dend
Wow this sure is an awesome car lots of details niceeeee ;)
montrealte31
What!!!!
Awesome work! It gives me a nice direction thanks!
montrealte31
Here is what i have done for now:
Your guys are smart ;)
