advice with nos fogger kit
Need info on what kit to get an where to nos my 3tc project
- Attachments
- 20130610_220630-1.jpg (53.87 KiB) Viewed 12256 times
Re: advice with nos fogger kit
http://www.jegs.com/i/NOS/741/05030/100 ... oreDetails. This is what I used on my set up its a wet system 4-foggers. http://www.jegs.com/i/NOS/741/05030/100 ... ProductId=
You will have to upgrade your ignition system from the picture it look stock to me ?
Thanks for the answers .. An yes is stock i m still working on it need a good fuel system ,, ignition, an a few things but i want to get all these things ready for this summer . Any other comments or advice is really appreciated thanks
lock the dizzy the webers don't need much fuel around 4lbs and another fuel pump for the NOS >wet system< and retard timing to around 24 degrees
if you change piston to high compression then you need to up the jetting on the webers also..hope my lil input helps
Yes it helps an thanks again or by the way i already have the intake drilled an foggers an pluming done i need to see if i can get the set up without that .. Ill post new pics of the car soon
Don't wanna use nos just plug the holes with small bolts with Teflon tape no leaks it will work fine
Yeah im gonna use it i bought the webbers an intake an it had the foggers an pluming already done so im looking to get the rest of the set up .. Toyotero when u had the set up how fast were u running ? an my foggers are there pluming is done do u know where i can get every thing else im gonna need ... Thanks for the help too
You can get a purge valve kit ,to bleed the system I got all my stuff from jegs,,,Holley fuel pump,,fuel regulator,,fuel gauge,,braided hose...
2step colder sparkplug to!
