Page 1 of 3
Swinger MMMM Love It
Posted: Fri Nov 22, 2013 2:18 pm
Re: Swinger MMMM Love It
Posted: Fri Nov 22, 2013 2:19 pm
Posted: Fri Nov 22, 2013 2:21 pm
give my car some love on the floor boards before installing the new carpeting i got laying flat on my guest room king size bed!
Main studs and gridle mocked up so the machine shop can do the machining on the block like align hone, bore, decking, block plate honed, also the crankshaft job and balance the rotating assembly with fluid dampr and billet flywheel,
Clutch kit from spec clutches ordered, ARP head bolts damper bolt, flywheel bolts ordered with a melling HV oil pump wit bolt set, all from Mancini,
Here is the clutch kit from SPEC Clutches, it looks serious holding power rated at 700+ HP so i should be ok with my goal of 550HP
Posted: Fri Nov 22, 2013 2:24 pm
Simple Electronics are here long time ago just i didnt have a chance to show em to you guys, A new MSD Pro Billet Distributor, MSD Digital 6 with 2-step, timing retard rev limit and many other things i dont know yet how to use, plus a MSD blaster SS coil,
As well as the new brake plumbing, the complete brand new wiring for the whole car from head lights to tail lights, Melling HV oil pump, Oil pump fasteners, ARP Head bolts, ARP harmonic balancer bolt, Mancini Flywheel bolts, roller pilot bearing And 3 bolt Mancini cam snout bearing,
Posted: Fri Nov 22, 2013 2:25 pm
Posted: Fri Nov 22, 2013 2:26 pm
Posted: Fri Nov 22, 2013 2:35 pm
Posted: Fri Nov 22, 2013 2:37 pm
