3TC Turbo ?'s
- skellington
Re: 3TC Turbo ?'s
1 Back to turbo questions: What would be a good price friendly / readily available turbo to run in a stock 2tc engine? I am thinking somewhere in the 150-175 HP range.
2 Would you recommend an intercooler?
I have a t5 Garrett from a 4cyl Volvo, but I think it is for too large of an engine and I'm sure the pitch of the turbines are all wrong. I would like to run 91 octane.
1974 TE27 TWINS!
#2 viewtopic.php?f=27&t=2036
Re: 3TC Turbo ?'s
it will work as long as you dont overboost it but keep it in the safe zone of 5 psi and thats it "only".
my set up just as an fyi.
hx35 turbo T3 flange
1.8 bored 87mm
forged eagle rods wiseco 7:1 compression pistons
head work done up the butt
double valve springs
stainless steel valves
bronze valve guides
5 angle valve job
turbo cam and degree wheel
balanced everything
log exhaust manifold evil140
2tg intake maifold
1200cc injectors RC
bosch 044 fuel pump
-8 pressure feed line
-6 return
efi ms2 v3.0 with edis4 for spark
and thats just to make 475hp on the safe side
1.8 bored 87mm
bronze valve guides
5 angle valve job
balanced everything
2tg intake maifold
1200cc injectors RC
bosch 044 fuel pump
-6 return
Re: 3TC Turbo ?'s
I like the simplicity of your build 475HP is an lot
hemilove wrote:it will work as long as you dont overboost it but keep it in the safe zone of 5 psi and thats it "only".
1.8 bored 87mm
bronze valve guides
5 angle valve job
balanced everything
2tg intake maifold
1200cc injectors RC
bosch 044 fuel pump
-6 return
Re: 3TC Turbo ?'s
In for dino videohemilove wrote:it will work as long as you dont overboost it but keep it in the safe zone of 5 psi and thats it "only".
1.8 bored 87mm
bronze valve guides
5 angle valve job
balanced everything
2tg intake maifold
1200cc injectors RC
bosch 044 fuel pump
-6 return
Re: 3TC Turbo ?'s
Carlos is that HP Horse Power or CH Cabra Power just kidding bro
Re: 3TC Turbo ?'s
Lol its chuppa cabra power!BOBLOOK wrote:Carlos is that HP Horse Power or CH Cabra Power just kidding bro
Its taken I while but I'm almost there brochachos
Re: 3TC Turbo ?'s
What trans will you be using for this power level. Pretty similar to the levels I'm looking for.hemilove wrote:it will work as long as you dont overboost it but keep it in the safe zone of 5 psi and thats it "only".
1.8 bored 87mm
bronze valve guides
5 angle valve job
balanced everything
2tg intake maifold
1200cc injectors RC
bosch 044 fuel pump
-6 return
1980 TE72 Wagon.
Instagram @wagonsteeze
Re: 3TC Turbo ?'s
Extremely happy to hear that. Been on edge about my W58 holding up, glad someone says it willhemilove wrote:W50 steel case homie its good for the power
1980 TE72 Wagon.
Re: 3TC Turbo ?'s
Look runs 9.7s on the 1/4 mile witha celica tranny and makes close to 500 hp check the vids. This means the trany holds power. http://m.youtube.com/watch?v=6R_Yn5-5w6 ... TPpoHGJJBM
