				Any ideas? Parts wanted.
				Posted: Sun Nov 03, 2013 2:57 am
				by Luisito
				I wanted to know everyones opinion, i have a stock 3tc 1.8. Later down the road wanted to add a few things
Want to know best part brands and best fits.
Idk too much about aftermarket parts, other than stock lol.
Header ( which fits and performs best )
Full exhaust ( dont want it loud ) cat, muffler etc..
Weber ( tipical, the one everyone has )
I want to keep it 1.8 3tc but i want it 5 speed and for it to perform better.
Who ever has ideas or PHOTOS of there work, let me know what i should go for?
Tatequieto
Will
Pufito
Something like yours
Stock but performance
Oh.. Also my starter keeps messing up i changed it about 3 times in the past 2 years
Also would like a stronger alternator. More volts basically something that fits on without modifications that let more power.
				Re: Any ideas? Parts wanted.
				Posted: Sun Nov 03, 2013 1:13 pm
				by mikealike
				Luisito wrote:I wanted to know everyones opinion, i have a stock 3tc 1.8. Later down the road wanted to add a few things
Tatequieto
Will
Pufito
Parts for t series are slowly diminishing since the new engines are more popular. I used Doug Thorley headers and a mildly ported head with a 32/36 weber carburetor, small 292 cam. Exhaust i used was a mandrel 2.5 tube exhaust with a silencer and a 50 series flow master.   Ignition to use is a MSD 6 series unit.
				Posted: Sun Nov 03, 2013 2:56 pm
				by Luisito
				Sounds good, and your right these performance parts are going to be difficult to find a couple years from now. That's why I want to perform my engine so it can run stronger. I want to keep up to a Honda basically lol. Stock I actually did pretty well keeping up. Do you have any pics?
				Posted: Tue Nov 05, 2013 1:32 pm
				by toyotero2dend
				hey Luisito  my old engine has a 296 cam,,alil porting on the head,,, short intake,, dual 45 side draft ,,a msd 6al ,, header  is a pacesetter ,,exhaust 2 1/2" ,, muffler 2 chamber  flew master ,,if  you can get your hands on a tranny  out of the twin cam corolla  they a bit stronger ,, and also the differential ,, as per  the charging, you can get an alternator out of a 1st gen rx7  they work great all you need to do is grind abit off  the  corolla  bracket ,, get a  bronze clutch  and a good pressure plate ,,  you be good to go
				Posted: Mon Dec 09, 2013 1:18 am
				by TPR Motorsports
				Ur starter problem is just bad connections to your starter solenoid, that one wire has several connections n over time they get corroded, u can trace the wire on the switch on the steering colomn n run a wire straight from there to the starter solenoid, starter problem fixed!!! I do this to all my corollas, works everything when I start getting the clicking issue with the starters.
Good luck man
				Posted: Tue Dec 10, 2013 6:59 pm
				Was your starter issue the click illness ??
For the starter you can use the saturn conversion
				Posted: Wed Dec 11, 2013 12:03 am
				by toyotero2dend
				do the relay for the starter Bob has the instructions in his post
