Anyone running 15x8 +20?
Posted: Fri Nov 01, 2013 1:28 am
by marsmann
Interested in seeing any pics of anyone running 15x8 +20, specifically on a TE51 coupe or liftback. Just trying to get an idea of how far they would stick out.
Thanks!
Re: Anyone running 15x8 +20?
Posted: Sat Nov 02, 2013 1:59 am
by Mazota TE51
Well I have 15x9 0 offset with 205/50's in the rear of my sportcoupe and its perfect although the 15x8 0 offset with 205/50's in the front stick out about 3/4-1" which tells me that a 15x8 +20 with a 195/50 would be perfect. Personally I am going to try running 195/50,s on my fronts to see if it will do the trick. Now that's only my assumption. Hope this helps.
Posted: Sat Nov 09, 2013 1:06 am
15x8 +20 offset is around 5.5 backspace a bit too much IMO but u can use a 1/2 or 1 inch spacer and done with it, but try to get the right offset, you wont regret it trust me!
Posted: Sun Nov 10, 2013 5:22 pm
by oldeskewltoy
On an E7 chassis... this is a 15 x 6.5 +22... a 15 x 8 +20 MAY interfere on the inside... it will be closer them mine below
