Te27 Wide flares
modify
Te27 Wide flares
Post by modify »
Previously I had put these up but the fiberglasser I was using moved, I have now found someone who can make the flares. Two sets are being made at the moment, with one set already spoken for and others can be made on request.
90mm at the front and 110 at the rear.
There are 4 individual flares one for each corner.
$400 AUD shipped (I had previously said it would be $415 but I have managed to shave some money of the fiberglasser)
They are molded to fit prefectly onto a ke25 and fronts will fit both ke20 and ke26s, some adjustment would be required to fit the rears to a ke20 or ke26.
They also could be modified to fit other old school Toyota's
This is how they look on my ke25
This is a te27 in Japan with them on.
donluv2uta
Re: Te27 Wide flares
Post by donluv2uta »
where r u located?
modify
Post by modify »
donluv2uta wrote:where r u located?
New Zealand
modify
Post by modify »
Bump
lopez286
Post by lopez286 »
how wide of a rim can you fit under it
modify
Post by modify »
lopez286 wrote:how wide of a rim can you fit under it
Depends on offset but I am running 14 x 9s at 0 at the back with a 25mm spacers and I could run 10s easily or 11's without the spacer. As for the front I am running 14 x8's at 0 with 20mm spacer but I could run 9's without the spacer or without the space and a bit more castor on them for clearance.
Obviously the offset affects fitment but there is a bit of room to work with.
Peace
modify
Post by modify »
Bump
modify
Post by modify »
Bump
modify
Post by modify »
Bump
modify
Post by modify »
Bump
