The Golf Ball shaped pistons in 2TC TE56 Project build.
Re: The Golf Ball shaped pistons in 2TC
Postby slaus » Wed Nov 04, 2015 2:15 pm
I called the guy, he got one set with the single valve relief and a few sets with same shape but double valve reliefs..
He wants $45 per piston complete with rings!
How much did you pay ??
slaus
Postby 73GTV » Sat Nov 14, 2015 1:16 am
That was so long ago that I do not remember, but it was less than $200.00 for the set. Here is an old picture of a used set which matched the NOS set that I purchased Single relief.
This is a 3TG Piston with duel reliefs, I'm just saying.
73GTV
Postby 73GTV » Wed Dec 20, 2017 4:01 am
Sorry, But after the Photo-bucket revolt, all of the old pictures I had, I just deleted them from Photo-bucket.
I remember this post prior to my relocation to the southeastern U.S. and have recently spotted more of these old pistons, just in time for the great experiment this winter.
Since I am earthbound due to an injury, it gives me time to dig up old stuff to rebuild. I have to find another source to post pictures, since I do not do "The Face'".
Any suggestions on where to post future pictures, rather than pay the Photo-bucket ransom.
73GTV
Postby 73GTV » Wed Dec 27, 2017 4:19 am
So is anybody still building and running these engines. Parts have almost dried up for these (New). Used parts are starting to become rare it seems.
73GTV
Postby 73GTV » Tue Jan 09, 2018 2:27 pm
Toyota Carina/Corolla Piston Set in .020 1.6 2TC 1975 - 1976 Only
RY6069-020 Round Dome
(actually 12T-U Pistons)(9:3 Compression ratio, Cast)
Import Engine Parts
2726 Washington Ave North
Mpls, Mn 55411
(612) 377-5745
(800) 999-5745
73GTV
Postby 73GTV » Tue Jun 12, 2018 3:40 pm
https://www.fitinpart.sg/index.php?route=product/product&product_id=63450
Here is a company that has the Air Filters for this housing. note that all of the new filters issued from Toyota are plastic as the originals were rubber and these are rubber.
73GTV
Postby 73GTV » Tue Jun 12, 2018 4:23 pm
2TB-2TBR Air Filter Housing from the Netherlands
Took the Lid and cleaned it up and placed it with the NOS Bottom from Spain
Painted the Lid with 2000 degree black paint, but it had a flat finish!
Repainted the Lid with a gloss black
The reason I'm showing you the bare manifold is to bring awareness to an expensive trick from a seller in Greece, His posting of his set of Carburetors for sale did not include a photo that was clear enough for the purchaser to realize that the elbow from the intake manifold to the water bypass had been removed and not included in the sale. One can be sourced.
Had to clean the parts from the set from down Under. The ad stated as is, but I was aware that the throttle plates would possibly be frozen as many of the remaining carburetor had possibly been stored with fluids still inside or had collected enough water or moisture which would rust the base assembly shut.
I will take them somewhere and eventually get them hot tanked or acid dipped once I figure out where stuff is located here in the near Atlanta area.
So I fitted this manifold with a set of spare carburetors until I can get the OEM base assemblies rebuilt and operating without resistance. This is just a mock-up for now. To use these would require a bit of effort in fabricating a new throttle cable system for these Carburetors.
Bad ankle or not, at least I'm doing something towards this project.
73GTV
Re: The Golf Ball shaped pistons in 2TC TE56 Project build.
Postby BOBLOOK » Thu Jun 14, 2018 5:50 pm
Nice glad to could help
What part of the intake is missing ?
Postby 73GTV » Fri Jun 15, 2018 6:20 pm
This is the part that is missing.
73GTV
Postby BOBLOOK » Sat Jun 16, 2018 6:05 pm
Are you looking for that particular part ?
PreviousNext
Return to Engine and Drivetrain
