Clutch for a 3tc with w50 tranny
Posted: Fri Oct 11, 2013 1:39 am
by baldo
So Im about to get a w50 already set up for a 3tc. So can I use the 3tc clutch? Is the input shaft splines the same?
Re: Clutch for a 3tc with w50 tranny
Posted: Fri Oct 11, 2013 12:04 pm
by ulises_te72
the shaft spines is bigger on the w50 tranny. Here is the lynk for the clutch you need...
http://www.euroexportinc.com/3tc/compet ... 1620c.html
Good Luck
Posted: Sat Oct 12, 2013 1:53 am
by baldo
So this will fit the 3tc pressure plate? I have been looking at some kits and they are bigger. This is my last question about it, I know more about engines than clutches and trannys. Thanks man!
Posted: Sat Oct 12, 2013 3:32 am
by ulises_te72
Yes, it will fit the pressure plate and flywheel.
Posted: Wed Jul 23, 2014 10:01 pm
by BrianGT
Thank you for that link! It's just what I need for my W58 to 2T/3T gearbox conversion.
Cheers.
Posted: Thu Jul 31, 2014 5:52 am
by njccmd2002
if you dont mind me asking, how was this tranny prepared?
adapter plate? because i have one with adapter plate, and wonder if the shaft would have to be shortened bacause of this...
Posted: Thu Jul 31, 2014 10:34 pm
by hemilove
nope but they have told me to weld the 3tc bellhousing to the trans so it has more room to hold on too but I used the adapter plate and that clutch it works well just do a normal break in and your set
