Hi Guys,
Where is the best place to get a good signal for my aftermarket tach?
I've added a pic, could someone point out where to connect the wire?
Thanks!
Where to get a good Tach signal
- Teun
- Contact:
--=...Lowest BHP title owner...=--
Re: Where to get a good Tach signal
Some ignitors have an extra tach output wire....... most don't has.
You will have to hook the tach to the negative - of the coil.... the green wire on most aftermark tach
- Teun
- Contact:
thanks, so the right one on the white bar in the pic?
negative wire of the Ignition coil.
No thats still a plus reduced voltTeun wrote:thanks, so the right one on the white bar in the pic?
Negative coil
- Attachments
- ign2ani.gif (17.87 KiB) Viewed 6824 times
