1980 TE72 3T-C
1980 TE72 3T-C
Hello Everyone! I am new to 3tcgarage. I’m currently working on bringing a 1980 te72 station wagon back to life after sitting 10+ years. It is a pretty-much stock, California car, so it has the vacuum line octopus with all the never ending emission check valves. After spraying what felt like the entire engine looking for vacuum leaks I finally found it! I’ve got a leak at the Mixture Control Valve (located under the intake, closer to firewall with 2 vacuum lines coming out of it) It is stuck open at all times when it should only be open at decel. I have been unable to find a replacement part. If anyone has any station wagon parts or might know where I can find this emission part please share! Thank you!
Re: 1980 TE72 3T-C
Welcome on 3tc garage, you request for the parts can be better post in classified wanted section.
