Like the title says . I'm looking for either the slip yolk or the entire driveshaft for a T50 transport that has a 20 spline output shaft.
Thanks.
20 spline driveshaft slip yolk WANTED.
Re: 20 spline driveshaft slip yolk WANTED.
Have you had any luck? I am also in need of one
hi, new user here. I may have what you are looking for. Does the slip yoke you need have the master tooth at 12 and 6?
