Transmission questions
Postby 1300cctuner » Mon Sep 03, 2018 2:03 pm
I have a 81 Corolla 3tc t50 trans and trans siezed up on m e. Found a t50 from a 83. Swapped the guts and tail shaft into 81 3tc casing. Out put shaft was a 20 spline and now the 83 is 22 spline now. Does anyone know where to get a new yoke and would i be able to just swap it on my old driveshaft with new u joint? I can only assume the length should be the same as far as driveshafts go right?
Re: Transmission questions
Postby 73GTV » Wed Sep 05, 2018 12:11 am
1300cctuner wrote:I have a 81 Corolla 3tc t50 trans and trans siezed up on m e. Found a t50 from a 83. Swapped the guts and tail shaft into 81 3tc casing. Out put shaft was a 20 spline and now the 83 is 22 spline now. Does anyone know where to get a new yoke and would i be able to just swap it on my old driveshaft with new u joint? I can only assume the length should be the same as far as driveshafts go right?
Go to the Toyota dealer parts department and at least see what the correct part number and availability for this item is and then you stand a better chance of someone being able to locate one for you.
If you were in SoCal I would be able to suggest parts yards where you stand a small chance of finding the correct Driveshaft Yoke. Place your location under your screen name please. Thanks
Return to Engine and Drivetrain
Users browsing this forum: No registered users and 5 guests
