Charging problems question
Pattywagon92
Post by Pattywagon92 »
Just bought this and new to these cars. 80 Corolla wagon. Was told and looks to have a new alternator battery and voltage regulator. But the alternator has nothing plugged into it nor does the voltage regulator, what plugs up to those?
Pattywagon92
Re: Charging problems question
It seems the previous owner cut out the connector wires. I can't find any remains of anything similar to the voltage reg. Connector or alt pig tail. Would the Saturn alt swap be the best way to go from here. Pretty difficult to finding info on these car any help is really appreciated
Those plug need to be attached to this voltage regulator unless he converted to Inbuilt regulator.
What alternator is mounted ?
Pattywagon92
It had a stock alternator on It. But there are no plugs anywhere for the alternator or voltage regulator. But I decided to the Saturn upgrade. I'm in the middle of switching the pulleys , been working like 12 hours a day so not much time left to work on it.
