Hey guys will an SR5 differential direct bolt into a TE31?
If not, what should I be looking for as an upgrade from my current rear end?
Any advice or comments are greatly appreciated!
SR5 diff
Re: SR5 diff
What model is the SR5?? are those coil spring or leaf-spring ?
- skellington
Re: SR5 diff
I have heard that all 6.58 diffs are compatible. The most you might have to do is drill holes to match some driveline bolts. can anyone confirm this?
1974 TE27 TWINS!
#2 viewtopic.php?f=27&t=2036
- skellington
Re: SR5 diff
I am speaking of the 3rd member that holds the gears. You can put that inside your current axle setup.
1974 TE27 TWINS!
