Page 1 of 2
building boost
Posted: Sun Oct 04, 2015 10:36 pm
by mallito1.8
Ok so here's a dumb question I think. My car when I use the 2 step with msd 6al and reving around 5-6000 rpm my gauge is not reading boost I check for leaks when I was on the dyno it only did 10#'s of boost and this is one of my issues that's getting to me I have a blow thru set up and a manual boost controller and it's maxed in I had a flange reeled thinking it was leaking there I can't run my car up and down the street to see if it needs to be under load so is it that it needs to be under load ? I need some opinions or help causing I'm ready to quit and sell after dumping so much money into my car. Opinions please
Re: building boost
Posted: Mon Oct 05, 2015 12:41 am
by mikealike
two step and a timing retard will make it boost up.
Re: building boost
Posted: Mon Oct 05, 2015 1:26 am
by mallito1.8
I'm using my msd 6al with a 2 step box controlling rev control and line lock button with rev cut or do I need to use something else?
And I do have a boost timing retard box.
Re: building boost
Posted: Mon Oct 05, 2015 2:01 am
by mikealike
Send me email addy I have the box you need
Re: building boost
Posted: Mon Oct 05, 2015 2:11 am
by mallito1.8
Re: building boost
Posted: Mon Oct 05, 2015 2:36 am
by mallito1.8
So how's this gonna solve my issue?
Re: building boost
Posted: Mon Oct 05, 2015 3:08 am
by mikealike
If you have no leaks in the turbo system when this is activated it will make the car boost up of the line, consistent launches and consistent times.
Re: building boost
Posted: Mon Oct 05, 2015 1:21 pm
by mallito1.8
Well another issue that I'm trying to figure out is that around 2500 to 3500 sh rpm it breaks up like foul plugs and then take off like a bat out of hell I called msd and they told me poor signal and to check power wires and wires to ignition so that's another issue I have to solve first.
Re: building boost
Posted: Mon Oct 05, 2015 2:45 pm
by mikealike
carb out injected?
Re: building boost
Posted: Mon Oct 05, 2015 3:48 pm
by mallito1.8
Carb is new it's electrical issue I'm betting on either bad wiring or bad msd
