Drivetrain upgrade options?
82 SR-5.
Id love to get a LSD but does it only come in a GTS?
I heard the automatics had better gears? I don't know if he meant rear end or what.
where can I find gears for these cars?
Whats recomended for a daily driver and daily racer set up?
Im on high way a lot, but I feel like I have about roughly 2-3000 RPM.
Re: Drivetrain upgrade options?
And the only benefit is the LSD only in the GTS model?
Yeah and the ration option stock is 4.3 what i can remember and is not what you need for highways
Dang what a let down.. Wish there was more but I guess when(IF) I find a GTS ill make my move
If theres no way to change gears can I use an ae86 or supra rear end?BOBLOOK wrote:Yeah and the ration option stock is 4.3 what i can remember and is not what you need for highways
I know te72 chassis is almost the same as ae86..
Also ae86 upgrade to supra.
Does anyone know about this?
I'm looking for pretty direct bolt on.
Thanks everyone!
Ae86 is direct bolt one supra need modificationsKenny727 wrote:If theres no way to change gears can I use an ae86 or supra rear end?BOBLOOK wrote:Yeah and the ration option stock is 4.3 what i can remember and is not what you need for highways
Thanks everyone!
Gears ae86 are expensive
So I can put in the stock AE86 for a LSD?
If rear end is 6.7in T series toyhead restoration sells gearsets ring and pinion for that rear end. here is link. copy and paste in address bar should work
http://toyheadauto.com/Celica_Parts_197 ... __Clutch__
Greg
Greg
its a TA 27 not a TE 27
