Took apart fuse box to clean and noticed this (pics)
Kenny727
Post by Kenny727 »
I took apart my fuse box to try to clean it.. Next I have to change out some starting system wiring. It seems my car might not activate the regulator to get power from the alternator?
Anyways while looking I seen the main power one was burnt bad, but mostly on the plastic.
I cleaned everything, scrubbed all terminals, added new dielectric, but noticed it looks like some of the pieces inside the fuse block broke and lost connection...Idk could just be a weird design..
inside fuse block.jpg (24.26 KiB) Viewed 4768 times
Well I disassembled it and cleaned everything.. I thought I was being carefull keeping each layer of connectors together.
Well I have some left over which makes me very nervous.
Does anywhere have a diagram? can I just plug the old harness into a universal fuse block, if not is there a car close to the same?
