No plug for my manifold?
Kenny727
Post by Kenny727 »
I took off my carb to clean and in the process unplugged my manifold(map sensor, or IAT?)
I put it back together, and since air inj, and PS was removed by previous owner, i somehow mixed up the wiring and can not find where the wire went!
So what color is this wire and where is it coming from?
I need a new fuse box and need to re run everything in the engine bay!
Kenny727
Re: No plug for my manifold?
Post by Kenny727 »
IS it common for the fuse box to fail? What are popular replacements?
I'm still looking for my manifold plug.
Also I found this on the drivers side down by the headers
unknown connector plug.jpg (25.92 KiB) Viewed 7641 times
ITs the round connector closest to the exhaust pipe. I dont see anything in the area, and since Im having starting issues I think It might be important
That round plug look like the the brake master cyl brake fluid level switch !
Also manifold doesn't have any sort of plug on it what ii recall
Kenny727
Post by Kenny727 »
Ill check it out, thanks and the manifold sensor must be something a past owner put in..
Not sure why... Ill go take a picture anyways to be sure, will edit this post later.
