1973 Toyota corolla deluxe 1.7l 2tc bored over 2b pistons ARP headbolts,hi flow oil pump, cam was ground at web cams in Riverside,CA medium duration street strip grind, the car in idle has some what of a lope, its an 8500rpm screamer motor, 11:1 compression can only run on 91 and up. Also has a flame thrower coil pack, stock double barrel carb body but the jets have been replaced with a .38 jets so it drinks more fuel. I bought the car off a young woman in la puente ,CA , she got into an accident in the car which is the damage on the driver side door and driver quarter , which i have both new quarter panel and new door. I got into an accident in the car , which is the damage on the passenger fender apron, i also have have panel to replace that. I was planning to pull the damage out and get the correct measurements up top, I was Only half an inch away, then make my cuts on the bent fender apron, and graft the new one in. Im still very much interested in this car, but my current situation is not allowing me the freedom to get everything done so selling might be an option. Like I said the car Is Currently non opt , it has an original title status. I have the pink slip in my name.
** The engine is currently out of the car , I was working on it**
As for parts I have a whole other car and then some:
-Driver Quarter panel
-Passanger Quarter panel
-spare tire trunk panel
-shifting hole tunnel panel
-Passanger fender apron panel
-Blue hood - good condition needs finish work, has trim
-red hood - bent needs body work, has trim
-blue fender set- rusted out , have emblems enact
-red fender set- bent , have emblems enact
-White door Set - minor body work
-Blue door set- Minor body work
-Back bench seat decent condition , does have some tares
-13in rim hub caps, just the caps No rims
- wiring harness
- fuel rails
- Air condition assembly
- Quarter vents
- AC vents
- Driver & Pass Quarter Glass
- front strut tube assembly set
- Driver mirror
- Rear Passenger window
-Kp61 Manual steering rack
-Kp61 Steering column
-74 Valance
-71 Valance
-73 Round Valance lights
- Emissions Box
-2tc engine 1.6l Stock early 5 port head
- interior knee guard moldings
- Sun visors
- Rear view Mirror
- Deluxe gauge cluster
- Ash tray assembly
- Stock Steering column with key
This is just stuff I can remember
there are a few more odds and ends
Asking $3500-OFFERS ON THE PACKAGE AS A LOT, EVERY LAST NUT, BOLT, PIECE, PART.
It all has to go, I really want my garage cleared out and to start fresh on a different project , not only that i'm going to be moving, and I cant move until all my stuff is out. Im very motivated to sell my car and all parts, I want it all gone asap, the car will have to go away on a flat be trailer you will also need a cargo van or box truck for all the parts. If you are Interested Give me a call or text 9513796639 my phone does not send picture messages , if you text me your Email Address I can Email you the Most recent pictures of the car. Im located In Moreno Valley, CA Inland Empire
Te27 Car + parts
Re: Te27 Car + parts
Do you happen to have seat belts you want to part with?
bryanhernandez3727
How much for the Kp61 Manual steering rack, Kp61 Steering column ?
Corolla Kid
トヨタ
トヨタ
bryanhernandez3727
