replaced starter still doesnt turn over engine
replaced starter it worked fine the first day but then it didnt want to turn over so my uncle unplugged the a/c it started normally then the next day it did the same thing so my uncle put in a starter switch for it to turn over there i s current coming from the starter but it wont turn over the engine without the starter need help
corolla lifestyle
Re: replaced starter still doesnt turn over engine
"there i s current coming from the starter but it wont turn over the engine without the starter need help". Well yes the engine wont turn over without the starter....... Was the starter new? How are the battery cables? Is the ground cable clean of dirt? So if you connect the starter straight to the battery it works?
Not really getting wat's you problem
Check the positive cable check for voltage draw if it is good it should be 0.00v if bad 0.05 check positive continuity at battery and at starter post then check at battery post to the starter solinoid check ground cable tap your starter also make sure your starter is tightend well to your transmission
