Looking for pistons.
Posted: Wed Oct 22, 2014 2:39 pm
by gotae86
Hey guys,
I'm planning on rebuilding my 2TC over the winter, oh Canada. I currently have golf ball pistons in it and I want to get more power from this engine.
Question 1, what is the compression ratio for these stock pistons?
Question 2, what sort of power would I get from 11:1, 12:1, 13:1 CR pistons, with a mild-ish cam?
I have an MSD 6AL for ignition, OER Racing carbs (45mm) for fueling.
Thanks,
Gerry
Re: Looking for pistons.
Posted: Wed Oct 22, 2014 4:24 pm
by oldeskewltoy
gotae86 wrote:Hey guys,
Thanks,
Gerry
What are you looking for when you are finished? Drag racer, hot street car, road racer...
Ideally you want to match the compression to the camshaft, so asking a compression question, while giving us a vague camshaft variable... will not offer you a great deal of useful answers. What camshafts are you considering (duration and lift)?
Posted: Wed Oct 22, 2014 8:06 pm
by gotae86
I'll be using the car for drifting and lapping days.
The cam I was looking at was the Schnieder 288F cam, Duration (gross): 288 and Valve Lift*: .504"
:D
Posted: Thu Oct 23, 2014 12:24 am
by oldeskewltoy
gotae86 wrote:I'll be using the car for drifting and lapping days.
:D
Part Number: N/A
Grind Number: 288F
Intake Duration (gross): 288
Exhaust Duration (gross): 288
Intake Duration (.050”): 254
Exhaust Duration (.050”): 254
Intake Valve Lift*: .504"
Exhaust Valve Lift*: .504"
Lobe Separation: 108
Intake Valve Lash: .018"
Exhaust Valve Lash: .018"
RPM Range:
3200-7200
*Based on 1.4 Rocker Arm Ratio
there isn't a timing card I could find (to verify intake valve closing event)... but 288 duration is going to call for compression above 11 to 1 (in my humble opinion) The Schneider cam lists 3200-7200, so there isn't going to be a lot of low end with this cam.
Posted: Thu Oct 23, 2014 2:13 pm
by gotae86
What would be your guess at horsepower at the wheels?
Does anyone have dyno graphs of their setups?
Posted: Fri Oct 24, 2014 1:31 am
by oldeskewltoy
gotae86 wrote:What would be your guess at horsepower at the wheels?
it truly depends on the quality of the build...
poorly put together with improper machining, and poorly matched parts... under 100hp, and a dog to drive... With the correct machining, parts and assembly, ~135 whp
Posted: Fri Oct 24, 2014 3:45 am
by gotae86
oldeskewltoy wrote: it truly depends on the quality of the build...
Sounds like a good time in a lightweight car. Thanks for chiming in.
