The old turbo setup.
baldo
Re: The old turbo setup.
Post by baldo »
^ really? You must be joking!!! :o :o :o :x :x :x
808TurboCorolla
Post by 808TurboCorolla »
I promise that is a stock 2T stock head and valves with a small norris cam and dual springs. 18psi pump gas! No bullshit :D
The setup I have in the new car is the same motor same 2T same cam and head. All I did was make a good flowing turbo manifold and put a 44 mikuni with a little water/meth and the car does 11.20's 122 best mph on 18psi with pump gas! I will try to load the pictures from that build tomorrow.
@baldo: I am just using a MSD pump 40psi 40gpm with a 1:1 reg.
slaus
Post by slaus »
808TurboCorolla wrote:I promise that is a stock 2T stock head and valves with a small norris cam and dual springs. 18psi pump gas! No bullshit :D
Shawn is that you???? @ 808TurboCorolla
Mazota TE51
Post by Mazota TE51 »
Very impressive.
admayen
Post by admayen »
Hola mano. I'm running a 32/36 weber with turbo also on my Corolla and until now I've never had the car run better than anything else and I've tried many different carbs. This one by far is the best one. Este carburador es el mejor que e tenido especialmente para manejarlo en la calle. Gracias por poner las fotos! Thanks for the pics.! :D
Post by Toyota1515 »
I want to see videos!
Post by mikealike »
looks great!!! More pictures please
808TurboCorolla
Merry Christmas to you all! I will try to look for more pics of my old car, and I will try to upload a few videos that I have when I get a chance. Sorry I have been away from 3tcgarage for a while. Life has been busy, you know how that goes.
Take care my friends
Merry Christmas bro
Island Chain Racing
Post by Island Chain Racing »
Gotta chime in, everything is all true...I seen his car first hand and in action ..and trust me its even better in person...as we say "faka action"...keep up the good work.
