Dose the te72 and the ae86 have the same length in drive shafts??
I have a buddy selling me a swap for a ae86  it comes woth motor mounts and drive shaft and a sr20det and djsut woundering if it would bolt up?
						drive shaft ae86 te72
Re: drive shaft ae86 te72
I don't think so because if the ae86 has the 6.7 rearend, the rearend is longer so the driveline is shorter.
On my racecar when I changed from the 8 bolt rearend to the 10 bolt celica rearend I had a solid driveline made and I ended up knocking the pinion gear out when the car would squat under acceleration just from the different length of the rearend pumpkin.
I'm sure they had to shorten the driveline a little for the different rearends from te72 to ae86.
If they both have the 6.3 then I bet it is the same length for both cars since they are both. Basically the same chassis with a t50.
				Dj Flights
Thanks for the answer. I think I'm gonna purchase it anyway and ill let you know if it fits and I have a 4 door tr72 with a t50 that's why I ased.
