Page 1 of 2
Battery/alternator question
Posted: Tue Jul 15, 2014 5:15 am
by totorote27
What's the best way to determine if a battery is no good or the alternator is no good?
Re: Battery/alternator question
Posted: Tue Jul 15, 2014 11:17 am
Posted: Tue Jul 15, 2014 11:19 am
Posted: Sun Aug 03, 2014 9:56 pm
by tron1.8
Disconnect the battery with the car on. If it dies, then the alternator is bad.
Posted: Wed Nov 05, 2014 1:37 pm
by hemilove
Best way i know is get a hydrometer pop the covers check the acid and test for spacific gravity if they are low in acid add distilled water and charge for 4-8 hours on low charge then test batter again for specific gravity if bad the that means that there is a problem in the cells but if good after charge then do a load test with the load tester in the first pic then connect it all up to your car and turn on the car with the clamp put that over the wire going to the positive and switch your multimeter to amps and your posts also if it reads that there are amps going through then you are good also for voltage draw at the positive cable it should be 0.00v to 0.04 anything above and you got a problem somewhere. That is how you check to see if all is well also make sure you belt is good and snug
Posted: Thu Nov 06, 2014 11:17 am
The majority of battery is sealed nowaday make measuring the acid difficult but yes best way to test an battery. The principle i do daily working on forklift trucks battery's
Posted: Thu Nov 06, 2014 3:34 pm
by hemilove
Electrical forklift or ic
Posted: Thu Nov 06, 2014 4:07 pm
hemilove wrote:Electrical forklift or ic
Both
Posted: Sun Nov 09, 2014 2:13 pm
by hemilove
Bad ass man me to i dont like junghinrick elecktric they are very special but other than that all else is fine
Posted: Sun Nov 09, 2014 5:55 pm
hemilove wrote:Bad ass man me to i dont like junghinrick elecktric they are very special but other than that all else is fine
For 13 year now fixing the same German brand ! Sometime we work on multi brands toyota, Junghinrich, Linde and others.
I have an van incorporate with tools and few parts move from one customer to another ad location.
