HEADLINER CONSOLE FOR TE51
Posted: Fri Jun 27, 2014 6:13 pm
IM NEW TO THE WEBSITE. BUT BEEN FAMILAR WITH COROLLA'S,CELICAS SINCE MY EARLIER YEARS AS A KID. ANYWAY I WILL CUT TO THE CHASE. I WORK AT A SALVAGE YARD AND I'VE BEEN WORKING ON MY TE51 THAT I SAVED FROM THE JUNKYARD AND I STUBBLED ACROSS SOMETHING I WOULD LIKE TO SHARE. I SAW THIS IN A PICTURE OF A TE51 THAT WAS UP FOR SALE AND IT LOOK PRETTY GOOD. THE OVERHEAD CONSOLE CAME FROM A 96-00 S10 BLAZER AND IT ONLY TAKE 3 SCREWS TO HOLD IT UP. YOU WILL HAVE TO ELIMINATE THE REAR VIEW MIRROR FOR THE SCREW UP FRONT AND GO WITH ONE USED ON THE WINDSHIELD. THE BACK SCREWS ARE WHERE THE DOMELIGHT IS ONE THE CONSOLE AND IT IS IN THE SAME PLACE WHERE THE O.E. DOMELIGHT ON THE TE51. ALL YOU WILL NEED IS TO PLACE A SMALL PIECE OF WOOD TO CATCH THE SCREWS CORRECTLY AND WIRE UP THE LIGHTS. THE CONSOLE HAS A PLACE FOR THE GARAGE OPENER AND SUNGLASSES AND HAS THE FRONT/BACK MAP LIGHTS WHICH GOES GOOD FOR THE BACK SEAT AND THE LARGE DOME LIGHT.YOU WONT BE ABLE TO USE THE OUTSIDE TEMP MONITOR BUT I CAN I LIVE WITHOUT IT. JUST WANTED TO SHARE THIS WITH YOU.
THANKS
THANKS
